925
igPivotView destroy
I'm having problems trying to destroy igPivotView object.
If I call destroy method on igPivotView and then try to redraw the object, an error is displayed, saying that the DataSelector is not properly set:
 $("#pivotGrid").igPivotView("destroy");
 $("#pivotGrid").igPivotView(options);
This raises the error:
TypeError: Unable to get property 'option' of undefined or null reference
  at _setOption (http://localhost:60207/Scripts/ignite/modules/infragistics.ui.pivotview.js:30:4815)
  at Anonymous function (http://localhost:60207/Scripts/jquery-ui-1.11.3.js:415:5)
  at $.Widget.prototype._setOptions (http://localhost:60207/Scripts/jquery-ui-1.11.3.js:665:4)
  at $.Widget.prototype.option (http://localhost:60207/Scripts/jquery-ui-1.11.3.js:657:3)
  at Anonymous function (http://localhost:60207/Scripts/jquery-ui-1.11.3.js:526:6)
  at each (http://localhost:60207/Scripts/jquery-2.1.3.js:374:6)
  at jQuery.prototype.each (http://localhost:60207/Scripts/jquery-2.1.3.js:139:3)
  at $.fn[name] (http://localhost:60207/Scripts/jquery-ui-1.11.3.js:523:4)
This is the row where the error occurs:
// infragistics.ui.pivotview.js:30:4815
this.dataSelector().option("dataSource",this.options.dataSource);
If I replace igPivotView with igPivotGrid+igPivotDataSelector, everything is shown successfully.
Should I try something else to destroy the object?
Thank you, Maria
