We face following porblem, how to fix that ?
Any Update ?
Any update ?
Hi Georgiev,
Issue was fixed at that time, but now it is reproduce again and tooltip is cutting from bottom. Please see ChartTooltip attached sample application.
Sufyan
Thank you so much, your provided solution solved our problem and its save a lot of time.
Hello Abu,
You can handle mouse move event, and you can check if the tooltip is outside of the window.
1 2 3 4 5 6 7 8 9 10 11 12 13
$(document.body).on('mousemove', function() { var $tooltip = $('.ui-chart-tooltip'); var windowHeight = $(window).height(); var tooltipTop = parseInt($tooltip.css('top')); var tooltipHeight = $tooltip.outerHeight(); var tooltipBottom = tooltipTop + tooltipHeight; if (tooltipBottom > windowHeight) { $tooltip.css('top',
tooltipTop - (tooltipBottom - windowHeight)); } });
Let me know if you need further assistance.
