25
Ignite UI Chart in AngularJS with Web API - can not push to Null
Need help. I am doing a very simple application do create a Ignite UI chart in the AngularJS app consuming data from Web API
  1. I am using AngularJS Ignite UI library from here :  https://github.com/IgniteUI/igniteui-angular
  2. I am able to create Ignite UI chart using the static data ( Not calling the service or web api)
  3. I am able to create HTML table using the data returned from the web api
  4. I am not able to create Ignite UI chart using the data returned from the web api.
Always getting the error as shown in the image below :
For reference codes used are given below:
Service
var app = angular.module('dataservice', []);
app.factory('populationData', ['$http', function ($http) {
    var populationData = {};
    populationData.data = function () {
        alert("hi");
        return $http.get('http://localhost:56649/API/CITIES');
    return populationData;
Controller
var myapp = angular.module('myapp', ['igniteui-directives', 'dataservice']);
myapp.controller('dataChartController', ['$scope', 'populationData', function ($scope, populationData) {
    getData();
    function getData() {
        populationData.data()
            .success(function (cities) {
                $scope.a = cities;
                console.log($scope.a);
                alert($scope.a);
            .error(function (error) {
                $scope.status = 'Unable to load customer data: ' + error.message;
                console.log('error');
View
<!DOCTYPE html>
<html ng-app="myapp">
<head>
    <title>Ignite UI Chart in AngularJS Demo</title>
    <!--For IG Chart-->
    <link href="Content/Infragistics/css/structure/infragistics.css" rel="stylesheet" />
    <link href="Content/bootstrap.css" rel="stylesheet" />
    <script src="Scripts/modernizr-2.7.2.js"></script>
    <script src="Scripts/jquery-2.1.3.js"></script>
    <script src="Scripts/jquery-ui-1.10.3.js"></script>
    <script src="Scripts/Infragistics/js/infragistics.core.js"></script>
    <script src="Scripts/Infragistics/js/infragistics.dv.js"></script>
    <script src="Scripts/Infragistics/js/infragistics.lob.js"></script>
    <script src="Scripts/angular.js"></script>
    <script src="igniteui-angular.js"></script>
    <script src="Service.js"></script>
    <script src="default.js"></script>
</head>
<body class="container">
    <div class="row" ng-controller="dataChartController">
        <h1>Ignite UI + AngularJS</h1>
        <h2>Countries Population</h2>
        <div class="row">
            <table>
                <tr ng-repeat="c in a">
                    <td>{{c.Name}}</td>
                    <td>{{c.Population01}}</td>
                </tr>
            </table>
        </div>
        <div class="row">
            <ig-data-chart id="datachart1" data-source="a">
                <axes>
                    <axis name="NameAxis"
                          type="categoryX"
                          title="Name"
                          label="Name"></axis>
                    <axis name="PopulationAxis"
                          type="numericY"
                          minimumvalue="0"
                          title="Milions of People"></axis>
                </axes>
                <series>
                    <series name="2001Population"
                            type="column"
                            is-highlighting-enabled="true"
                            is-transition-in-enabled="true"
                            x-axis="NameAxis"
                            y-axis="PopulationAxis"
                            value-member-path="Population01">
                    </series>
                </series>
            </ig-data-chart>
            <!--<ig-zoombar target="#datachart1"></ig-zoombar>-->
        </div>
    </div>
</body>
</html>
Any help ? or connect me with someone who can help !
error
