I am using classic ASP because this is an older application. I can get the control to render just fine but I can not set the value of the text area. Also, I need to retrieve it the value of the html so I can store it.
Any ideas?
That worked! Thanks for the help.
Hi ericlarson,
Such functionality will be added for the next volume release due to the fact that current volume release had the html editor as a CTP, but until then I can suggest you the following workaround.
//editorId is the id of the element the html editor was initialized.var editorWorkspaceId = "#" + editorId + "_editor"$(editorWorkspaceId).contents().find("body").html(); // Get the html from the editor$(editorWorkspaceId).contents().find("body").html("Some HTML"); // Set the html for the editor
Best Regards,Bozhidar Cherkezov
