Hi
I am working on a ASP.NET project.I am new to Infragistics.
I have a requirement to add check box column dynamically. I have 3 fixed columns those are BoundFields.
My Requirement is,
After bunding 3 fixed columns I have to add checkbox column dynamically in the code behind and need to bind value based on value getting from the database.
or
Please suggests me any other best option. Please find grid view screenshot and code.
Please provide me some sample code would be appreciable
Design View:
I need to make column dynamic marked in red. Currently these columns are static. I need to make all checkbox column dynamically binding
Code
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid" runat="server" Width="100%" AutoGenerateBands="true" AutoGenerateColumns="false" DataKeyFields="IQuestionId" EnableDataViewState="true" CollapseButton-ImageUrl="~/images/colapseMinus.png" CollapseButton-HoverImageUrl="~/images/colapseMinus.png" CollapseButton-PressedImageUrl="~/images/colapseMinus.png" ExpandButton-ImageUrl="~/images/expandPlus.png" ExpandButton-HoverImageUrl="~/images/expandPlus.png" ExpandButton-PressedImageUrl="~/images/expandPlus.png" CssClass="headerRow" GroupingSettings-GroupedBandCssClass="headerRow"> <Behaviors> <ig:Selection Enabled="false" CellClickAction="Row" RowSelectType="None"> </ig:Selection> </Behaviors> <GroupingSettings EnableColumnGrouping="True" GroupAreaVisibility="Visible" InitialRowExpandState="Collapsed" /> <Columns> <ig:BoundDataField DataFieldName="IQuestionId" Width="0%" Key="IQuestionId" Hidden="true" Header-Text="" /> <ig:BoundDataField DataFieldName="VchQuestionText" Width="30%" Key="VchQuestionText" Hidden="false" Header-Text="Question Text" /> <ig:BoundDataField DataFieldName="VchSectionName" Width="0%" Key="VchSectionName" Hidden="true" Header-Text="Section Name" /> <ig:BoundDataField DataFieldName="VchQuestionType" Width="15%" Key="VchQuestionType" Hidden="false" Header-Text="Question Type" /> <ig:BoundDataField DataFieldName="VchAnswerType" Width="15%" Key="VchAnswerType" Hidden="false" Header-Text="Answer Type" /> <ig:TemplateDataField Key="TempMedical" Header-Text="MedicalTest" Width="8%"> <ItemTemplate> <asp:CheckBox ID="chkMedical" runat="server" Checked='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Medical") %>' /> </ItemTemplate> </ig:TemplateDataField> <ig:TemplateDataField Key="TempAviation" Header-Text="AviationTest" Width="8%"> <ItemTemplate> <asp:CheckBox ID="chkAviation" runat="server" Checked='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Aviation") %>' /> </ItemTemplate> </ig:TemplateDataField> <ig:TemplateDataField Key="TemSecurity" Header-Text="Security" Width="8%"> <ItemTemplate> <asp:CheckBox ID="chkISecurity" runat="server" Checked='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "ISecurity") %>' /> </ItemTemplate> </ig:TemplateDataField> <ig:TemplateDataField Key="TemTechinical" Header-Text="Techinical" Width="8%"> <ItemTemplate> <asp:CheckBox ID="chkTechinical" runat="server" Checked='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Techinical") %>' /> </ItemTemplate> </ig:TemplateDataField> <ig:TemplateDataField Key="TemLogistics" Header-Text="Logistics" Width="8%"> <ItemTemplate> <asp:CheckBox ID="chkLogistics" runat="server" Checked='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Logistics") %>' /> </ItemTemplate> </ig:TemplateDataField> </Columns> </ig:WebHierarchicalDataGrid>
I have modified the sample demonstrating how the sorting works from the code-behind. Your issue could be caused by e.RowIsland.DataMember being empty(as it is in the sample since a DataSet is used) or being with a different name.
Please test the sample on your side and let me know whether it helps you achieve your requirement.
1033.Sample.zip
Thanks for your quick response. I tried the below code from the help topic , But still sorting is not working for me
This is my Page load code I am adding after binding data into the grid
this.WebHierarchicalDataGrid.RowIslandDataBinding += new RowIslandEventHandler(WebHierarchicalDataGrid_RowIslandDataBinding); in page load.
WebHierarchicalDataGrid is my grid ID,
protected void Page_Load(object sender, EventArgs e) {
MessageControl.HideMessage();
if (!IsPostBack) { this.WebHierarchicalDataGrid.Columns.Clear(true);
BindToGrid();
if (IsPostBack) { this.WebHierarchicalDataGrid.EnsureTemplates(); }
After initializing the RowsIslandDataBinding event , I am creating the event method
void WebHierarchicalDataGrid_RowIslandDataBinding(object sender, RowIslandEventArgs e) { // Sort a Column in PARENT BAND if (e.RowIsland.DataMember == "SqlDataSource1_DefaultView") { Sorting sort = e.RowIsland.Behaviors.Sorting; sort.SortedColumns.Add("vchMainSection", Infragistics.Web.UI.SortDirection.Ascending); } // Sort a Column in CHILD BAND if (e.RowIsland.DataMember == "SqlDataSource2_DefaultView" && e.RowIsland.ParentRow == this.WebHierarchicalDataGrid.GridView.Rows[1]) { Sorting sort = e.RowIsland.Behaviors.Sorting; sort.SortedColumns.Add(e.RowIsland.Columns[2], Infragistics.Web.UI.SortDirection.Ascending); } }
Still Sorting is not working.
ScreenShot of my Grid
Red highlighted one vchSubsection as per my requirement 1. Trip Objective should come first.
I tried to sort by iSectionID which identity is column(1,2,3..). But it was not working ,then I have appended 1 and 2 before each vchSubSection column to sort in ascending order in the grid.That one also not sorting properly.
Below one is screenshot of my Dataset to bind Grid
I am doing grouping by Column[1].ie, vchMainSection after grouping I am trying to do sorting by
Column[2] .ie, vchSubSection
I am using infragistics assembly version --> Assembly="Infragistics45.Web.v16.2, Version=16.2.20162.2013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Please help out how to do sorting after grouping by vchMainSection Column.
I have do sorting by sub section marked in red first screenshot or another other option also fine for me to achieve sorting.
Please also suggest me if any other options.
I am waiting for your help.
My suggestion is to take a look at this help topic.
I have modified and attached the previous sample, demonstrating how to sort a given column using JavaScript method mentioned in the topic for your reference.
Please let me know if you need more information.
6712.Sample.zip
Thanks for reply.Its working fine.
I have some issue related to Sorting WebHierarchicalDataGrid .. Below is my code where I am binding dynamically generated columns to WebHierarchicalDataGrid .
WebHierarchicalDataGrid.DataSource = ds; GenerateBoundFieldColumn(); GenerateTemplatedColumn(xmlConfigSection, dtBindConfig, isSaved); this.WebHierarchicalDataGrid.GroupingSettings.GroupedColumns.Add("vchMainSection"); this.WebHierarchicalDataGrid.GroupingSettings.GroupAreaVisibility = Infragistics.Web.UI.GridControls.Visibility.Hidden; WebHierarchicalDataGrid.DataBind();
The below code I am dynamically creating BoundField
public void GenerateBoundFieldColumn() { BoundDataField boundField = new BoundDataField(); boundField.Key = "vchMainSection"; boundField.Header.Text = "Section Name"; boundField.Width = Unit.Percentage(18);
BoundDataField boundFieldSubSection = new BoundDataField(); boundFieldSubSection.Key = "vchSubSection"; boundFieldSubSection.Header.Text = "Section Name"; boundField.Width = Unit.Percentage(18); boundField.Hidden = true;
BoundDataField boundFieldSectionID = new BoundDataField(); boundFieldSectionID.Key = "iSectionID"; boundFieldSectionID.Header.Text = ""; boundFieldSectionID.Hidden = true; boundField.Width = Unit.Percentage(0); boundField.CssClass = "clmDisabled";
this.WebHierarchicalDataGrid.Columns.Add(boundField); this.WebHierarchicalDataGrid.Columns.Add(boundFieldSubSection); this.WebHierarchicalDataGrid.Columns.Add(boundFieldSectionID);
My issue is, I want to sort by specific integer column (iSectionID) which is already hidden.
I want override Groupsettings order by. I want to default sorting based on iSectionID.
Please help me out how to do sorting after grouping or suggest me the possible way to customize based on specific integer column.
In order for the template to be available, the EnableDataViewState property of WebHierarchicalDataGrid has to be set to true. Then inside the click handler, the EnsureTemplates method has to be called.
I have modified and attached the sample I had sent to meet your new requirement. Let me know if that solves your issue.
3681.Sample.zip
