1255
Found the problem adding IgniteUI to a Blazor Project
There is an upcoming problem that the development team should know about as is it related to new Microsoft Changes.
I created a new Microsoft Aspire Solution from their Visual Studio template.  It creates a Blazor project that does not have either an Index.html or a _layout.cshtml file.  They load the contents of those files in App.razor.
They also dont use "var builder = WebAssemblyHostBuilder.CreateDefault(args);" ,  the new Blazor application uses"var builder = WebApplication.CreateBuilder(args);" instead to create the project.
The loading of "_content/IgniteUI.Blazor/app.bundle.js" now only partially works.  While some of the UI renders, some of it does not.  An Infragistic IgniuteUI List will show a list but onclick will not work.  The IgniteUI button will not respond to an onclick event and part of the UI doesnt render.
This is the new App.Razor file...
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <base href="/" />
    <link rel="stylesheet" href="bootstrap/bootstrap.min.css" />
    <link rel="stylesheet" href="app.css" />
    <link rel="stylesheet" href="AspireOfm.Web.styles.css" />
    <link rel="icon" type="image/png" href="favicon.png" />
    <link href="_content/IgniteUI.Blazor/themes/light/material.css" rel="stylesheet" />
    <link href="_content/IgniteUI.Blazor/themes/grid/light/material.css" rel="stylesheet" />
    <link href="css/ig-theme.css" rel="stylesheet" />
    <link href="css/app.css" rel="stylesheet" />
    <link href="">fonts.googleapis.com/css rel="stylesheet">
    <link href="">fonts.googleapis.com/icon rel="stylesheet preload prefetch" as="style">
    <HeadOutlet />
</head>
<body>
    <Routes />
    <script src="_content/IgniteUI.Blazor/app.bundle.js"></script>
    <script src="_framework/blazor.web.js"></script>
</body>
</html>
