How to use IgbDropdown?
I've been using Infragistics productions for years, but I'm unable to load data from a datasource using the IgbDropdown.
1. None of the documentation seem to be working for the dropdown.
2. There doesn't seem to be a datasource, text, or value field.
I'm unclear how this should work?  Also, why do I have to be moderated every post?
PS: Within two minutes, I was able to get a full example from your competition?
Sean
  • 29105
    Suggested Answer
    Hello Sean,
    Thank you for contacting Infragistics.
    The IgbDropdown is aimed at being a more simplistic component not relying on binding. If you have a datasource you wish to bind to the simplistic thing is to use the IgbMultiColumnCombo. You can use it's Fields property to assign which column(s) you want to display. You can still loop into a list and add items to an IgbDropdown if you aren't binding.
