25
Error in Grid when using decimals
I am evaluating the grids which you offer and they are quicker than some of the other grids on the market, however, i am seeing an issue when i use decimal values.
The console is showing an error stating:
Unhandled exception rendering component: Unable to set property 'DataSource' on object of type 'IgniteUI.Blazor.Controls.DataGrid'. The error was: Blazor.platform.readInt64Field is not a function
I can replicate this on the sample dataset in your examples where i changed one of the "double" datatypes to a decimal. This also happened when i added an int64 datatype.
I don't know if this is something i am doing incorrectly but this also happens when i dont have any of the decimal values in the columns.
Any advice would be greatly appreciated
  • 140
    I had a look at your issue with converting to and using decimals in the grid and was not able to reproduce the issue you are experiencing using version 20.2.38 I have attached a sample if you can modify it to show the issue you are experiencing or if you can send me an isolated sample showcasing the issue, I may be able to help you further.
    BlazorDataGrid.zip
