515
doubt regarding targeting element
Hello  everone,
I just i need alil help with the following
I m really confused with the following:-
1) $("#grid").igGridUpdating("editorForKey", "id");
2) $("#grid").igGridUpdating("editorForKey", "id").data(igvalidator)
3)$("#grid").igGridUpdating("editorForKey", "id").data(igvalidator). element.
Does the first one provide the column value? And why we cant use first one to target the column in which we have to change the required property and what does the second one give?.Also what does .data(igvalidator) do?
Looking forward to you response.
  • 460
    I have been looking into your question and I noticed that the same question is discussed in the following forum thread.
    Please keep in mind that according to our support policy we handle single support case/forum thread per query. This helps us ensure that all your issues are addressed correctly.
    I will continue assisting you via other forum thread regarding the validation in the igGrid control and if you have any questions related to the issue originally discussed in original forum thread, please ask it there.
    Please keep in mind that is good if everything about one question, as in the case of igGrid validation, is discussed in one forum thread, and not to make many such questions in different forum threads on separate fragments from the original discussed matter.
    You will find an answer to your question in the main forum thread here.
    Thank you for your cooperation.
