Model:
public class Product { public int ProductID { get; set; } public string Name { get; set; } public string ProductNumber { get; set; }
public List<ProductLocations> Locations { get; set; } }
public class ProductLocations { public string Address { get; set; } }
Controller
[GridDataSourceAction] [HttpPost] public ActionResult PostDataMethod3(Product Param1, string Param2, string Param3) { try { List<Product> products = new List<Product>();
products.Add(new Product { ProductID = 1, Name = "Product 1", ProductNumber = "12345" }); products.Add(new Product { ProductID = 2, Name = "Product 2", ProductNumber = "12346" }); products.Add(new Product { ProductID = 3, Name = "Product 3", ProductNumber = "12347" }); products.Add(new Product { ProductID = 4, Name = "Product 4", ProductNumber = "12348" }); products.Add(new Product { ProductID = 5, Name = "Product 5", ProductNumber = "12349" });
return View(products.AsQueryable()); } catch (Exception ex) { string error = ex.Message; return null; } }
AJAX call
var appJson = { "Param1": { "ProductID": 1, "Name": "test product", "ProductNumber": "P123", "Locations": [{ "Address": "Address1" }, { "Address": "Address2" }]}, "Param2": "Param2", "Param3": "Param3" };
$('#postData3').click(function (e) { e.preventDefault();
$.ajax({ url: '@(Url.Action("PostDataMethod3"))', type: 'POST', traditional: true, contentType: "application/json", dataType: "json", data: JSON.stringify(appJson), success: function (response) { alert('Succcess'); $('#grid').igGrid({ dataSource: response }).igGrid("dataBind"); }, error: function (xhr, ajaxOptions, thrownError) { alert('Failure - ' + xhr.responseText); $('#grid').igGrid({ dataSource: null }).igGrid("dataBind"); } }); });
Eroor:
2022infragisticerror.igGridQueryStringToJson.zip
Taking [GridDataSourceAction] off the table is not a good idea. You are converting JsonResultset, however my application is massive and relies on [GridDataSourceAction] on a ton of screens. Whenever I call products.AsQueryable(), every one of my apps returns a View. geometry dash
Hello Anitha,
After an investigation, I have determined that the GridDataSourceAction attribute intended use is when the request is made directly from the grid using a ‘GET’ request. Using an external ‘POST’ ajax call like in the example provided the GridDataSourceAction throws an exception. What I can suggest is to create a duplicate method to be called when $.ajax is used that does not use the attribute but instead returns a JsonResult.
Regards, Aleksandar Atanasov, Infragistics.
No, it's not a good solution to remove [GridDataSourceAction]. my application is so big it full depended on [GridDataSourceAction] on lots of screens .. even your are converting JsonResultset. All my application using return View(products.AsQueryable());
I am expecting solution GridDataSourceAction why it's throwing exception if my payload has List or Array.You can could find path for GridDataSourceAction that helps a lot for all user who trying to to use Infragistics.Web.Mvc, Version=5.22.2.7.
After further investigation I was able to discover that the GridDataSourceAction attribute is used when filtering or paging is handled remotely by the server and it is not intended for a post request to the server. In order to achieve the desired behavior, what I could suggest is to remove the attribute and to convert the result in the PostDataMethod3 to json result object as below:
public ActionResult PostDataMethod3(Product Param1)
try
products.Add(new Product { ProductID = 7, Name = "Product 1", ProductNumber = "12345" });
JsonResult result = new JsonResult();
result.Data = products;
result.JsonRequestBehavior = JsonRequestBehavior.AllowGet;
return result;
Please test it on your side and let me know how it behaves.
I have done some work around this. It an issue with Infragistics.Web.Mvc, Version=5.22.2.7.
GridDataSourceActionAttribute throwing exception incase of request/response has array object.
If you can get solution for this that would be great.
