135
igDataChart
Hello I have some how to questions regarding the igDataChart.
I have an ASP.NET MVC using razor website. I am designing a weekly sales chart by product where I what to compare the sales of 1 to 5 different products with each other. The user will select from a list of products (up to 5) that they want to display on the cart. Because of this i need so dynamic configuration of the chart for the following:
  • Dynamically create and configure 1 to 5 series based on the data. Currently I have added 5 series to the chart but if the user does not select 5 products to display the chart still displays a flat line and the legend shows where there is not data for.
  • Dynamically populate the series Title. It seems that I cannot add a dynamic string to the title. The title should be the product name  where it also displays in the legend as well.
  • Configure the legend more robustly. For example adding a title and such to it.
  • When I export the chart using the example provided on this site, I would like the legend and title of the chart to be included in the export image.
The problem is all the online examples are in jQuery or JavaScript.
I don't want to use JavaScript or jQuery to do this. I would like to achieve this using Razor coding that I am used to.
Thank you.
Below is the current view source code:
@using Infragistics.Web.Mvc
@model eMerchant.Reports.Models.OrderWeeklySale
<div class="row">
    <div class="col-lg-12 col-md-12 col-sm-12 col-xs-12">
        <div class="row">
                <div style="color: #44ACD6">
                    <span>Event: </span><span style="font-weight: bold">@Model.EventName</span><br />
                </div>
            </div>
        </div>
        <div class="row">
            <div class="col-lg-12 col-md-12 col-sm-12 col-xs-12 justify-content-center">
                @(Html.Infragistics().DataChart(Model.OrderWeeklySales.AsQueryable())
                        .ID("chart")
                        .AlignsGridLinesToPixels(true)
                        .VerticalZoomable(true)
                        .HorizontalZoomable(true)
                        .OverviewPlusDetailPaneVisibility(Visibility.Collapsed)
                        .Legend(legend => legend.ID("dataLegend"))
                        .Height("400px")
                        .Width("100%")
                        //.Width("900px")
                        .Title("Weekley Sales by Product")
                        .Subtitle("")
                        .Axes(axis =>
                            axis
                            .CategoryX("xAxis")
                            .Title("Week")
                            .Label(item => item.Week)
                            //.Label(item => item.FirstDateOfWeek)
                            .Title("Week")
                            .LabelLocation(AxisLabelsLocation.OutsideBottom)
                            .Interval(1).LabelLocation(AxisLabelsLocation.OutsideBottom)
                            .StrokeThickness(2)
                            .MajorStroke("#f4f4f4")
                            .MinorStrokeThickness(1);
                            axis
                            .NumericY("yAxis")
                            //.MinimumValue(0)
                            //.MaximumValue(100)
                            .Title("Quantity Sold");
                        .Series(series =>
                            //series.Line("series1")
                            //series.Column("series1")
                            //series.Spline("series1")
                            //series.Point("series1")
                            .ValueMemberPath(item => item.Quantity1)
                            .Legend(legend =>
                                legend.LegendType(LegendType.Item);
                                legend.ID("dataLegend");
                            .Title("")
                            .XAxis("xAxis")
                            .MarkerType(MarkerType.Circle)
                            .MarkerBrush("#f0e723")
                            .MarkerOutline("#ffc200")
                            .YAxis("yAxis")
                            .ShowTooltip(true)
                            .Brush("#ffc200")
                            .Thickness(2)
                            .IsDropShadowEnabled(false)
                            .ShadowBlur(40)
                            //.ShadowColor("grey")
                            .ShowTooltip(true)
                            .TrendLineType(TrendLineType.None)
                            .TrendLineThickness(1)
                            .TrendLineBrush("#000000")
                            .IsTransitionInEnabled(true)
                            .TransitionDuration(2000)
                            .TransitionInMode(CategoryTransitionInMode.AccordionFromLeft)
                            .TooltipTemplate("Total Sales by Week")
                            .LegendItemVisibility(Visibility.Visible)
                            .TooltipTemplate("tooltipTemplate1");
                    //series.Line("series2")
                    //series.Column("series2")
                    //series.Spline("series2")
                    //series.Point("series2")
                    .ValueMemberPath(item => item.Quantity2)
                    .Legend(legend =>
                    .Title("ProductName2")
                    .XAxis("xAxis")
                    //.MarkerBrush("red")
                    //.MarkerOutline("blue")
                    .YAxis("yAxis")
                    .ShowTooltip(true)
                    .Brush("green")
                    .Thickness(2)
                    .ShadowBlur(40)
                    .ShowTooltip(true)
                    //.TrendLineBrush("orange")
                    .TooltipTemplate("tooltipTemplate2");
                    //series.Line("series3")
                    //series.Column("series3")
                    //series.Spline("series3")
                    //series.Point("series3")
                    .ValueMemberPath(item => item.Quantity3)
                    .Legend(legend =>
                    .Title("Quantity3 - X3X3")
                    .XAxis("xAxis")
                    .YAxis("yAxis")
                    .ShowTooltip(true)
                    //.Brush("green")
                    .Thickness(2)
                    .ShadowBlur(40)
                    .ShowTooltip(true)
                    .TooltipTemplate("tooltipTemplate3");
                    //series.Line("series4")
                    //series.Column("series4")
                    //series.Spline("series4")
                    //series.Point("series4")
                    .ValueMemberPath(item => item.Quantity4)
                    .Legend(legend =>
                    .Title("Quantity4")
                    .XAxis("xAxis")
                    .YAxis("yAxis")
                    .ShowTooltip(true)
                    //.Brush("green")
                    .Thickness(2)
                    .ShadowBlur(40)
                    .ShowTooltip(true)
                    .TooltipTemplate("tooltipTemplate4");
                    //series.Line("series5")
                    //series.Column("series5")
                    //series.Spline("series5")
                    //series.Point("series5")
                    .ValueMemberPath(item => item.Quantity5)
                    .Legend(legend =>
                    .Title("Quantity5")
                    .XAxis("xAxis")
                    .YAxis("yAxis")
                    .ShowTooltip(true)
                    //.Brush("green")
                    .Thickness(2)
                    .ShadowBlur(40)
                    .ShowTooltip(true)
                    .TooltipTemplate("tooltipTemplate5");
                        .WindowResponse(WindowResponse.Immediate)
                        .DataBind()
                        .Render()
            </div>
        </div>
        <div class="row">
                <div id="dataLegend"></div>
                <div id="columnChart"></div>
            </div>
                <input id="exportToPdfBtn" onclick="ExportImage()" value="Export as image" type="button" class="btn button01" />
            </div>
        </div>
    </div>
</div>
<!-- Format the Chart & Legend-->
    $(function () {
        $("#chart").igDataChart({
            chartType: "column",
            dataSource: data,
            legend: { element: "theLegend" }
    $("#dataLegend").igDataLegend({
        target: $("#chartContainer").igDataChart(),
        headerText: "My Custom Data Legend Header",
        summaryType: "total",
        summaryTitleText: "Grand Total"
</script>
<!-- Custom Tooltip Template -->
<script id="tooltipTemplate1" type="text/x-jquery-tmpl">
        <span>Week: </span><span>${item.Week}</span><br />
        ${item.ProductName1} Total Quantity Week ${item.Week}: <span style="font-weight: bold">${item.Quantity1}</span>
    </div>
</script>
<script id="tooltipTemplate2" type="text/x-jquery-tmpl">
        ${item.ProductName2} Total Quantity Week ${item.Week}: <span style="font-weight: bold">${item.Quantity2}</span>
    </div>
</script>
<script id="tooltipTemplate3" type="text/x-jquery-tmpl">
        ${item.ProductName3} Total Quantity Week ${item.Week}: <span style="font-weight: bold">${item.Quantity3}</span>
    </div>
</script>
<script id="tooltipTemplate4" type="text/x-jquery-tmpl">
        ${item.ProductName4} Total Quantity Week ${item.Week}: <span style="font-weight: bold">${item.Quantity4}</span>
    </div>
</script>
<script id="tooltipTemplate5" type="text/x-jquery-tmpl">
        ${item.ProductName5} Total Quantity Week ${item.Week}: <span style="font-weight: bold">${item.Quantity5}</span>
    </div>
</script>
<!-- Export the Chart to a File -->
    function ExportImage() {
        var img = $('#chart').igDataChart("exportImage", $('#chart').width(), $('#chart').height());
        // atob to base64_decode the data-URI
        var image_data = atob(img.src.split(',')[1]);
        // Use typed arrays to convert the binary data to a Blob
        var arraybuffer = new ArrayBuffer(image_data.length);
        var view = new Uint8Array(arraybuffer);
        for (var i = 0; i < image_data.length; i++) {
            view[i] = image_data.charCodeAt(i) & 0xff;
        var blob = new Blob([arraybuffer], { type: 'image/jpeg' });
        saveAs(blob, "img.jpg");
</script>
