I get a JavaScript error when attempting to use the IgniteUI template engine {{if}} statement in the code below. (I'm using this in an MVC model, when creating a GridModel GridColumn template.)
The first block of script fails with a JavaScript error. The second two blocks work without errors.
The only big difference I can see is that there are two {{if}} statements in the first block of code. If I comment either {{if}} statement out, the code works! But including both {{if}} statements generates an error.
Produces JavaScript error:{{if ${VG_GROUP} == 'True' }}<div class="d-flex align-items-center container" style="white-space: nowrap; font-size: 24pt;">{{else}}<div class="d-flex align-items-center container" style="white-space: nowrap; font-size: 12pt;">{{/if}} {{if ${VG_GROUP} == 'True' }} <img src="trigger-load-images-onerror" width="16" height="16" > {{/if}}</div>
This code works:{{if ${VG_GROUP} == 'True' }}<div class="d-flex align-items-center container" style="white-space: nowrap; font-size: 24pt;">{{else}}<div class="d-flex align-items-center container" style="white-space: nowrap; font-size: 12pt;">{{/if}}</div>
This code also works:<div class="d-flex align-items-center container" style="white-space: nowrap; font-size: 12pt;"> {{if ${VG_GROUP} == 'True' }} <img src="trigger-load-images-onerror" width="16" height="16" > {{/if}}</div>
It seems like your code is throwing a tantrum when both conditions are in play. It's like the template engine can only handle one {{if}} at a time without getting confused! temple run 2
I've been experimenting with different strategies in thief puzzle and I've found that planning ahead is important. Does anyone have any tips?
Free AI Tools Latest Merch Deals Remote Software Jobs
This essay is excellent. I appreciate you sharing.
slope 2
