I have an ASP.NET MVC Project and I'm trying to add Data Grid from this sample
https://www.igniteui.com/grid/aspnet-mvc-helper
but I have 2 problems
First one
using IgniteUI.SamplesBrowser.Models.Repositories;using IgniteUI.SamplesBrowser.Application.Data;
I have a red underline on these words ( Repositories - Application ) so I have errors in the Controller
Second one
In the view
<body>
@(Html.Infragistics() .Grid(Model) .ID("grid") .Width("100%") .Height("500px") .PrimaryKey("ID") .AutoGenerateColumns(false) .AutoGenerateLayouts(false) .Columns(column =>.........
</body>
I installed Infragistics.Web.Mvc form NuGet Package Manager but I have a red underline on this word ( Infragistics )
Can you solve this problems or give me any working sample?
Hello Sameh,
I am glad that you were able to solve your issue.
Monika Kirkova,
I followed your instructions and it's working nowThanks a lot
Regards
Sameh Refaaat
A possible reason for this exception could be if the Infragistics core and lob files are not included in the project. They could be referenced in two ways:
Additionally, jQuery should also be referenced only once within the application. Loading the scripts more than once will cause an exception.
Please keep in mind that by design the template for an mvc project has references for jquery scripts in the _Layout.cshtml file. What I could suggest is removing the following lines of code from the _Layout.cshtml in the “Shared” folder:
@Scripts.Render("~/bundles/jquery")
@Scripts.Render("~/bundles/bootstrap")
@Scripts.Render("~/bundles/modernizr")
Please let me know if you need any further information regarding this matter.
Hello Monika
I downloaded your sampla and add Infragistics.Web.Mvc reference
In visual studio I don't have any errors but when i run the project i got empty screen then i opened developer tools console and got these errors
Mixed Content: The page at 'localhost:44373/.../Index' was loaded over HTTPS, but requested an insecure stylesheet 'cdn-na.infragistics.com/.../infragistics.theme.css'. This request has been blocked; the content must be served over HTTPS.
Index:46 Mixed Content: The page at 'localhost:44373/.../Index' was loaded over HTTPS, but requested an insecure stylesheet 'cdn-na.infragistics.com/.../infragistics.css'. This request has been blocked; the content must be served over HTTPS.
5Mixed Content: The page at '<URL>' was loaded over HTTPS, but requested an insecure script '<URL>'. This request has been blocked; the content must be served over HTTPS.
Index:59 Uncaught ReferenceError: $ is not defined at Index:59
Then I changed all http to https and run the project again and i got this erroe in console
Index:59 Uncaught TypeError: $(...).igGrid is not a function at HTMLDocument.<anonymous> (Index:59) at j (jquery-1.11.3.min.js:2) at Object.fireWith [as resolveWith] (jquery-1.11.3.min.js:2) at Function.ready (jquery-1.11.3.min.js:2) at HTMLDocument.J (jquery-1.11.3.min.js:2)
so how can i fix it?
