I have created application .NET Core 3.x using razor pages. I am not sure how to binding works for the Igrid. Could you help me with binding works on this.
It's my cshtml.cs
[ActionName("GetRoles")]
public async Task OnGetAsync()
Role = await _context.Role
.Include(r => r.App).ToListAsync();
//GridModel gridModel = new GridModel();
//gridModel.ID = "grid1";
//gridModel.DataSource = _context.Role.AsQueryable();
//var paging = new GridPaging();
It's my razor page cshtml
@(Html.Infragistics()
.Grid(Model)
.ID("grid")
.Width("100%")
.Height("500px")
.PrimaryKey("RoleId")
.AutoGenerateColumns(false)
.AutoGenerateLayouts(false)
.Columns(column =>
column.For(x => x.RoleId).HeaderText("RoleId").Width("30%");
column.For(x => x.Description).HeaderText("Description").Width("30%");
.Features(features =>
features.Sorting().Type(OpType.Remote);
features.Paging().Type(OpType.Remote);
features.Filtering().Type(OpType.Remote);
features.Responsive().ColumnSettings(cs =>
cs.ColumnSetting().ColumnKey("RoleId").Classes("ui-hidden-phone");
cs.ColumnSetting().ColumnKey("Description").Classes("ui-hidden-phone ui-hidden-tablet");
.DataSourceUrl(Url.Action("GetRoles"))
.Render()
Hello Anitha,
The Infragistics.core, Infragistics.lob files and the Infragistics styles should also be referenced. They could be referenced in two ways:
If the files are referenced locally, the css and js folders from the Infragistics folder/2020.1/Ignite UI for jQuery should be included in the project and the following lines of code should be added in the _Layout.cshtml or Index.cshtml:
<link rel="stylesheet" href="">stackpath.bootstrapcdn.com/.../bootstrap.min.css" integrity="sha384-JcKb8q3iqJ61gNV9KGb8thSsNjpSL0n8PARn9HuZOnIxN0hoP+VmmDGMN5t9UJ0Z" crossorigin="anonymous">
<link href="~/css/structure/infragistics.css" rel="stylesheet" />
<link href="~/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
<script src="">ajax.aspnetcdn.com/.../script>
<script src="">code.jquery.com/.../script>
<script src="~/js/infragistics.core.js"></script>
<script src="~/js/infragistics.lob.js"></script>
More information regarding adding required resources could be found in the following topic.
Furthermore, in the following link I have attached the sample project with all the files, demonstrating the use of igGrid with data binding and the referenced scripts.
Please let me know if you need any further information regarding this matter.
Monika Kirkova,
Hi Monika,
Thank you. I created new .NET Core 3.1 project and removed all jQuery reference but still the grid is not visible on the page. you can see the page doesn't have any layout reference to bootstrap or jquery. Is there anything I need to setup in the startup project?
I use trial license is this something I need to check on. I am in the process of deciding to buy Infragistics so it's important for me to understand it clearly. Thank you.
A possible reason for this exception could be if jQuery is loaded more than once within the application. Please keep in mind that by design the template for a Razor pages project has references for jQuery scripts in the _Layout.cshtml file. What I could suggest is removing the following lines of code from the _Layout.cshtml in the “Shared” folder:
<script src="~/lib/jquery/dist/jquery.min.js"></script>
<script src="~/lib/bootstrap/dist/js/bootstrap.bundle.min.js"></script>
<script src="~/js/site.js" asp-append-version="true"></script>
After removing the scripts, the grid should be rendered and populated with data by using .DataBind().
Additionally the system has rejected the project because of its size. If they are still problems with binding data to the grid, what I could suggest is uploading the project to a drive and sending me a link for the project.
I followed your code and copied your code to the index model but the grid is not showing on the page. After Welcome the page is empty
I can't open your sample project in VS2019. I am creating project in VS2019
