355
PivotGrid - When I click a cell, i need to know the field names and and values for the row and column dimensions
I am working in Angular v17 with the Pivot Grid, v17.2. I have a pivot grid with 2 nested columns (Color and Coating) and 2 nested rows (State and Material). I am showing the number of orders as my value in the pivot grid. I have configured the cellClick Event so that I can see the event properties after I click. How can I get the values for Color, Coating, State and Material from the event.cell object that is exposed by the cellClick event?
To clarify - once I click on a cell, I need to know Color = 'a', Coating = 'b', State = 'c', and Material = 'd', so that I can query my database with that where clause to pull up all of the orders that match that criteria. Also, I would need to know the column name and values in any filters which were specified.  So if I have a filter on Group and I filtered to Groups A & B, I need to know that the filter is active and what is the field name(s) of the active filter(s), and what are the list of values used in the filters.
I was able to pull a map out of grid that gave me the row dimensions (both field names and values), but I have not seen where I can get the column dimension field names and values.
I was able to see the column dimension values by interrogating the _header property of the IgxGridCell, but I don't see where I would find the field name to relate to the value.
cellClick(event: IGridCellEventArgs) {
  let cc: IgxGridCell = event.cell as IgxGridCell
  console.log({cc})
  this.cc = cc
  let tc: any = {};
  Object.assign(tc, this.cc.column);
  do {
    console.log(tc._header)
    tc = tc.parent
  while (tc);
  let idx: number = cc['_rowIndex']
  let r = this.grid1.dataView[idx]
  console.log(r)
  let arr1 = Array.from(r.dimensionValues.entries());
  arr1.forEach((x:any) => {
    console.log(x[0],x[1])
Finally, I don't know how I would iterate through all filters to get the field names for each filter, and the values that were selected in each filter.
I am thinking that there must be some simple solution to this that I am not able to see by poking around in the grid and clicked cell object.
Thanks in advance.
I also posted this question on Discord, but I am not sure whether Discord is monitored by IG Support.
