Hello,I have a misunderstanding about the version upgrade.I've already done it using the "ng update" syntax, but this time I get an error message that I can't explain.
What should I do ?
I am glad that you were able to update the package successfully.
Regards, Monika Kirkova, Infragistics
Thanks for your help. I generated a new token and it's OK.
After an investigation, I have determined that this error message indicates that there is a problem with the credentials or with the .npmrc file.
Could you please try logging into our ProGet site and check if the @infragistics/igniteui-dockmanager is available under the js-licensed feed.
Additionally, the credentials used for setting up the private feed should be the same as the ones used for logging into the ProGet site. More information regarding setting the private feed could be found in the following topic of our documentation.
Furthermore, could you please share if a password or an access token is used for logging into our private feed, the current version of the project and the one that you are trying to update to.
Thank you for your cooperation.
