Hi team,
I am using Infragistics version 9.1.28 Hierarchal grid. Issue: Unable to set vertical scroll bar for Parent grid. And if i set the vertical scrollbar it is not scrolling through out the data. it just scrolls to the end.
After investigating this further, I have determined that if height is set to the grid and not all rows could fit in the view, a scrollbar is rendered by default. However, if all rows are displayed, no scrollbar is rendered.
I have prepared a sample demonstrating this behavior. Please test it on your side and let me know how it behaves. If the behavior is still reproduced on your side could you please modify the shared sample, in order to demonstrate the behavior and send it back to me.
Additionally, please keep in mind that according to our support policy Ignite UI for Angular version 9 is considered retired and it is no longer eligible for Developer Support Services.
Please let me know if you need any further information regarding this matter.
Additionally, I would like to let you know that due to upcoming holidays I will be out of the office and I will review any updates on 04/18 and respond to you then.
Regards, Monika Kirkova, Infragistics
Please reply ASAP
