Please refer to this
https://stackblitz.com/edit/angular-dgbhg2
In igx-simple-combo when white space added in displayText at the end of a string or start of a string
after that selection is not working. example link attached
Hello Shahab,
A developer is assigned to the issue and there is a pending PR regarding this behavior. You will receive notifications when new information is available.
Please let me know if you need any further information regarding this matter.
Regards, Monika Kirkova, Infragistics
Hi Monika Kirkova,
Thanks for your reply. this suggestion will be a work around not a proper solution. I thinks it should be fixed on Infragistics side
After investigating this further, my suggestion is to log this behavior in our GitHub repository here. This will give you the opportunity do directly communicate with our development team regarding the issue and get notifications whenever a new information is available.
When creating your issue be sure to be specific and provide as much details as possible. Attaching a working sample, screenshots and any information that consider relevant are going to be very helpful.
Additionally, what I could suggest as a workaround is to select the selected item in a method bound to the blur event of the combo input. This could be achieved as follows:
fromEvent(this.simpleCombo.comboInput.nativeElement, 'blur').subscribe( () => {
this.simpleCombo.select(this.simpleCombo.filteredData[0].id);
I have prepared a sample demonstrating this suggestion. Please test it on your side and let me know if you need any further information regarding this matter.
