I have to merge multiple Column's cells based on some condition (Basically on Time).
which is showing dynamic data
Hello Krishna,
Thank you for following up!
After further investigating this matter, I am under the impression that you require merging cells from separate records based on a certain condition, however, what I could say is that, at this point, we do not provide this functionality out of the box. It is considered a feature request and should be logged in our GitHub repository.
Additionally, I have noticed that such a request has already been logged here, and what I could suggest in order to have this feature implemented in any of our future releases, is to explain the context in which this feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Also, it would be great and extremely helpful if you could provide the answers to the questions from this conversation as well.
Please let me know if you need any further assistance.
Sincerely,Riva IvanovaEntry Level Software Developer
Hello Riva,
Yes based on the time I need to merged cells which is blurred and also DATE/ DAY/ TIME should also merge.
(like if program is 1 hour's then 2 cells and if 2 hour's then 4 cells should merge)
Thank you for posting into our community!
I have been looking into your question and the provided screenshot, however, I need to ask for some additional information.
Answering these questions would be highly appreciated and extremely helpful in providing you with a solution as soon as possible.
Additionally, I believe you will find our Multi-Row Layout topic very helpful as this feature allows splitting data into multiple visible rows. In this topic you can find multiple samples and API References as well.
However, if none of these samples is an accurate demonstration of what you are trying to achieve, could you please provide me with a small sample, which replicates your data structure, filled with some test records and the desired igx-grid functionalities so that I will be able to investigate it further.
Thank you very much for your cooperation on this matter.
Looking forward to your reply.
Here I am passing dummy image.
