I have an igx grid something like this
I want to reduce the column header size. I wanted to replace the 3 dots which open the filter and sorting menu.
Instead I want the filter and sorting menu to open when I click on the header itself. Also if possible I want to change the cursor to pointer while doing that.My Ignite version is 11.0.9
As per my previous comment, there are no events that would help handle the situation, so the best approach would be adding event listener to the toggle list from the conditional styling as well. Something like:
Sincerely,Tihomir TonevAssociate Software DeveloperInfragistics
your example didnt have the component
addEventListener would be the way to go, since there are not exposed any other related events to the excelStyleFiltering.
Regarding the conditional filter, this is not popping in the app that I have sent. Can you please let me know of the changes you have made that make it pop.
Looking forward to your reply.
Sincerely,
Yes Tihomir, it does close when I click apply.However, it doesn't respond when I click Cancel.I found a workaround using addEventListener, if you have an Angular way to do it that would be helpful.And I found another issue with the above implementation.The Conditional filters open behind the Excel filter.
It would help if I can catch when the Conditional filter is clicked so that I can close the ExcelFilter.Sincerely Thanks for your help.
Yes Tihomir, it does close when I click Apply.I saw the filteringDone function, It works when I click on Apply.Although I wanted to close the filter when clicked on the Cancel button (since the excel filter closes normally on Cancel).I found a workaround for that using addEventListener, if you have another solution that solves it using Angular ways please let me know.And I have faced another issue with IgxExcelStyleConditionalFilter inside the excel filter.The Conditional filter opens behind the ExcelFilter.
