Hello Team,
I am using Igx-grid which is loaded with more than 5000 records. I am facing the following issues with Igx Grid:
Hello Shobhana,
Please note that as I have mentioned in my previous response without having a small isolated sample reproducing the issue you are facing I won’t be able to investigate this matter further and provide you with a solution. As you can notice within the provided sample, there are more than 5 thousand records and no lag is observed.
Having this in mind please feel free to modify my sample so that it replicates the issue and send it back to me along with the exact version of the IgniteUI for Angular package you’re using in your actual project for further investigation.
Looking forward to hearing from you!
Best Regards, Martin Evtimov Associate Software Developer Infragistics, Inc.
Hello Martin,
Actually we are loading the grid data from API that holds around 2k of records.Issue: When trying to uncheck the boxes for 30 records, it is lagging. This is performance issue. Please help!!
Hello Kavya,
Thank you for contacting Infragistics Community!
In order to reproduce the issue you have described I have prepared the following sample. As you can observe there are more than 5000 records present in the igxGrid and when the header indicator is clicked all rows gets selected immediately without any lag. Having this in mind I assume that you’re using either remote data or grouped records.
In order to be able to assist you further could you please try to modify the provided sample so that it reproduces the described behavior and send it back to me for further investigation. This will allow me to debug it on my side and to provide you with solution as soon as possible.
Could you please attach your package.json file in your next response as well? I want to make sure that we’re testing the described behavior on the same version.
