I am using Igx-grid and row selection feature.
Scenario: When i select a row and delete a row and again select row the row selection event contains both previous row and current row in the new Selection array in handleRowSelectionChange() method.
Requirement: As we delete the current row, so when i select the row again i need the handleRowSelectionChange() method only contains the current row selected not the previous row.
As this is an ongoing project please respond to the query ASAP.
Thanks in Advance!!
As far as I tested, the issue is not reproduced on my side.
I attached a sample I used for testing. Here are the steps I used.1. npm install and npm start. Open browser's developer tool.2. Open localhost:4200 in a browser.3. Select one or several rows.4. Click "Delete" button.5. Select one or several rows.-> Observe the console of the developer tool and you'll see all the newSelection has is the rows you selected in the step 5.
f123590-app1.zip
I also have this problem. What is the solution?
Sorry to keep you waiting.
We are still looking into the inquiry. When there is any update, we will let you know.
Thank you in advance.
It is been a while, could you please provide an update.
