I am on Angular/Infragistics 12.0.3.
I am attempting to force a component reload on my scenario-details (parent) component based on changes made to the mappings (child) component.
I am emitting change events on the child component as below:
@Output() reportChanges = new EventEmitter<string>(); async deleteMapping(mapping:scenarioDesignFacility) { let response:any, confirmation:boolean = confirm(`Delete mapping ${mapping.design} for ${mapping.facility}?`); if (confirmation) { response = await this.scenarioService.deleteDesignFacilityMapping(mapping.id).toPromise(); if (response == 'OK') { this.dfMappings.splice(this.dfMappings.findIndex(m => m.id == mapping.id), 1); this.dfMappingsList.markForCheck(); console.log(`Successfully deleted mapping ${mapping.design} for ${mapping.facility}!`); this.reportChanges.emit('mapping deleted'); } } }; async updateDesignFacilityMapping(mapping:scenarioDesignFacility) { let response:any = await this.scenarioService.updateDesignFacilityMapping(mapping).toPromise(); if (response.statusCode == 200) { console.log(`Mapping ${mapping.design} for ${mapping.facility} successfully updated!`); this.reportChanges.emit('mapping updated'); } else { console.log(`Failed to update mapping ${mapping.design} for ${mapping.facility}: `, response); } }; async createDesignFacilityMapping() { let response:any = await this.scenarioService.createDesignFacilityMapping(this.newDf).toPromise(); if (response.statusCode == 200) { console.log(`Mapping ${this.newDf.design} for ${this.newDf.facility} successfully created!`); this.dfMappings.push(this.newDf); this.dfMappings.sort((a, b) => { if (a.facility !== b.facility) { return a.facility.replace('2', '02') < b.facility.replace('2', '02') ? -1 : a.facility.replace('2', '02') > b.facility.replace('2', '02') ? 1 : 0; } else { return a.design < b.design ? -1 : a.design > b.design ? 1 : 0; } }); this.dfMappingsList.markForCheck(); this.reportChanges.emit('mapping created'); } else { console.log(`Failed to create mapping ${this.newDf.design} for ${this.newDf.facility}: `, response); } };
I am attempting to listen and respond by reloading location as below:
<igx-tabs #scenNav [tabAlignment]="'justify'" *ngIf="scenario && scenario.name !== undefined && workweeks.length> 0" (tabItemSelected)="itemSelected()" [style.display]="isLoading ? 'none' : 'block'"> <igx-tab-item> <igx-tab-header class="bg-primary text-white"><span igxTabHeaderLabel>Design Facility Mappings</span></igx-tab-header> <igx-tab-content> <app-design-facility [id]="scenario.id" [scenario]="scenario" (reportChanges)="changeNotification($event)"></app-design-facility> </igx-tab-content> </igx-tab-item> </igx-tabs>
changeNotification(e:any) { this.dfChanges = true; }; itemSelected() { if (this.dfChanges) { location.reload(); } }
I am not getting any information from either tabItemSelected or tabItemDeselected events on igx-tabs. The documentation isn't clear on where these events should be emitted/listened to. I have tried them on both the igx-tabs enclosure (container for igx-tabs-item types) and directly on the igx-tab-item objects without positive results.
It is critical that the scenario-details component reload with mapping changes since every change (except the private flag) directly affects the visible data (private hides the mapping's existence from other users who are not admins in the design component).
There's an existing MVC version of the app and the newly separated .NET CORE API and Angular UI. The projects only share DB resources. Why would you think that merely separating would solve an issue not present as the result of a conjoined project?
) I would create my solution by separating the MVC project from Data project and things would work just well,
Hello Chris,
I’m glad that you find the provided information helpful.
Thank you for using Infragistics Components!
Best Regards,Martin EvtimovAssociate Software DeveloperInfragistics, Inc.
This works perfectly. Thanks!
Thank you for contacting Infragistics Community!
What I would suggest is subscribing to the selectedItemChange event as I have demonstrated in the following sample.
Please let me know if you need any additional information.
Best Regards, Martin Evtimov Associate Software Developer Infragistics, Inc.
