Is there a Dock manager simple example available that goes just slightly beyond the sample app? I'd like to embed a data chart or grid instead of a panel but I don't understand how to do it. I've tried looking at the data analysis example, but this is more complicated than I am ready for at this stage.
Thank you for the provided sample application.
After an investigation I determined that in order to display the chart with 100% height you should also set all wrapping containers height to 100%.
However, if you require to have only this chart in the entire pane you could remove all wrapping div-s and set the slot property to the chart itself:
<igx-data-chart slot="content4" class="dockManagerContent" #chart isHorizontalZoomEnabled="true" isVerticalZoomEnabled="true" width="100%" height="100%" [dataSource]="chartData"> .... </igx-data-chart>
Here could be found the modified sample for your reference. Please test it on your side and let me know if I may be of any further assistance.
Sincerely,Teodosia HristodorovaAssociate Software Developer
Thank you for that sample! Very helpful.
I have modified it a bit and put a chart in the "Document 2" tab. This works great for the most part. I have the width of the chart specified as 100% so it will resize with the dock window, but if I set height to 100% the chart disappears. How can I make the height of the chart fit the size of the dock window in the same way as the width?
Here is a fork of your sample with the chart embedded:
https://stackblitz.com/edit/dock-manager-with-grid-fiyhun
