Hi
I have igx-select in an edit template of a column in an igx-grid.
To activate it on switching to the edit mode I've decorated it with igxFocus='true'.
The problem is that on next 'enter' the select pops up but then gets closed automatically by the grid due to leaving of the edit mode
https://stackblitz.com/edit/github-srbuis-dpvliy
The question is how to open the popup on the fist 'enter' stroke or at least prevent closing on the second.
Thank you!
Thank you, Bozhidara, you solution works.
I'm just wondering if there is a way to do that in a centralized fashion besides inheritance?
public handleSelectKeyDown(event) { if (event.key === "Enter") { event.stopPropagation(); } }
