I am using angular 6 version hence i installed "igniteui-angular": "6.2.0" and the feature I want to use is igxtexthighlightdirective.
After npm run build I am getting following error:
Module build failed: @include igx-dark-theme($green-palette); ^ No mixin named igx-dark-the.
Here is my style.scss
Hello Shruti,
Тhe default light theme could be used, however, version 6.2 is considered retired and it is no longer eligible for Developer Support Services.
What I could suggest is upgrading to our latest version which at this point is version 11.1.
Regards, Monika Kirkova, Infragistics
Then which theme is useable and will the functionality be still working?
After investigating this further, I determined that the error message is displayed because the dark theme mixins are available since igniteui-angular version 7.0 and igx-fluent-dark-theme is introduced in version 8.2.
Furthermore, please keep in mind that support is applicable to two versions back - latest stable, and the previous major version This means that version 6.2 is considered retired and it is no longer eligible for Developer Support Services. The current LTS is 11.1.0, which means that support is also applicable to 10.2.x.
Please let me know if you need any further information regarding this matter.
