I'm trying to find the best way of using the snackbar component programmatically. The examples only show it being triggered in the HTML via other HTML elements. I wish to trigger it from the TypeScript programmatically, in response to internal behaviours (show errors, etc). I can't find what is the best/recommended way of achieving this? There are a number of methods described for inter-component communication, so I'm unsure which is best/easiest to work with the Ignite components.
Hello Coran,
Thank you for contacting Infragistics Support.
I have been looking into your requirement and what I can suggest is using the property decorator. You can access message from the typescript code using ViewChild:
@ViewChild("snackbar", { static: true })
public snackbar: IgxSnackbarComponent;
I have created a small sample in order to demonstrate suggested approach. For the purposes of the example, I added an input, where you can enter a message which you want to show.
Please feel free to continue sending updates to this case at any time.
Malin Hadzhiev
