15
ig-date-picker format change
Hi Team,
How can I change the format of date - to  below format- I want '.' separated  date month and year
Currently Date is coming in -   separated by '/'
I need dot instead of slash.
Thanks & Regards,
Sweeti
  • 720
    Hello Sweeti,
    Thank you for contacting Infragistics Community!
    I believe you will find the following sample I have prepared for you very helpful. As you can observe I’m using the igxDatePicker formatter function in order to display the date value in the desired format (dd.MM.yyyy).  In case you’re using the editable dropdown mode of the igxDatePicker I suggest setting its mask to the same (dd.MM.yyyy) so that in case the user try to modify the date via typing and not through opening the dropdown containing the calendar the date would remain in the same format. In case you’re using the dialog mode providing a mask string is not necessary.
    If this sample is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me for further investigation.
    Best Regards,
    Martin Evtimov
    Infragistics, Inc.
