45
Cell Style from string
hi, i'm trying to pass a string in the column using the [cellStyles] property but i get a css error. "SyntaxError: Unexpected token ( in JSON at position 69".
this is my string:
{"background": "linear-gradient(to right, #8ca6db, #b993d6)","color":(rowData, coljey, cellValue, rowIndex) => rowIndex % 2 === 0 ? "gray" : white"};
and this is the function that I use to send the value of the css to [cellStyles] :
public applyCSS() {
        var splitted = this.field.grid.cellStyles.split(";");
        splitted.forEach(element => {
            if (element!=null && element!='') {
                    var css= element.trim();
                        try {
                            var style = JSON.parse(css);
                            console.log(style);
                            this.field.headerGrid.forEach((column, index) => {
                                column.cellStyles = style;
                        } catch (error) {
                            console.log(error);
                            return false;
What should I do to correctly send that string in [cellStyles]?
