I am trying to add grid styling for igx angualr grid. With View Encapsulation None It is working perfectly fine but with View Encapsualtion Emulated the styles are not working.
I tried using
: host :: ng-deep{
@import '~igniteui-angular/lib/core/styles/themes/index';
with ng-deep it gives following error:
Overloaded function `rgba` given wrong number of arguments
in G:\TFR\node_modules\igniteui-angular\lib\core\styles\base\utilities\_functions.scss (line 499, column 26)
please let me know if there is a way to apply style without using view Encapsulation None
Hello,Thank you for contacting Infragistics Support.I managed to reproduce your problem and the only thing you need to do in order to be able to fix it is to take out @import '~igniteui-angular/lib/core/styles/themes/index'; statement outside the :host::ng-deep {}. I attached I small example where I override the default paging style without set the encapsulation property to none.If you have any additional questions or need further assistance, please contact us.igxGridStyle.zip
