Im evaluating Ignite for Angular for my next Project, testing, playing around.. you know the drill
I notice there is an App Template that can be used to get an application stared with the Ignite CLI that includes a side bar + Login funcionality,
Is there any samples, tutorials, blogs entry, etc that you can recommend... that I can use to understand a bit better how to use this template?
Just need some sort of a starting point ..
Thanks in advance.
Hello Roberto,
Thank you for contacting the Infragistics support!
The following wiki page should be a good starting point for exploring the Login functionality: https://github.com/IgniteUI/igniteui-cli/wiki/Angular-Authentication-Project-Template
Please, take a look at it and let us know if you face any troubles implementing the functionality or in case anything in the publication is not clear enough.
Thank you once more for using the Ignite UI CLI!
Best regards,
Alexander Marinov
