I have created an angular project which also has an angular library in which I need to install and use Ignite UI for angular. When I install it using the command "npm i igniteui-angular" and use NgxInputGroupModule in it, it starts giving build error given below;
NgxInputGroupModule
BUILD ERROR : Template parse errors: The pipe 'titlecase' could not be found ("dy-row"> <span *ngFor="let dayName of generateWeekHeader()" class="igx-calendar__label">[ERROR ->] {{ dayName | titlecase }} </span> </div> "): D:/GitProjects/BASFProj/projects/ssi- framework/node_modules/igniteui-angular/igniteui- angular.d.ts.IgxCalendarComponent.html@38:3 The pipe 'titlecase' could not be found ("Month($event)" [igxCalendarMonth]="month" [index]="i" *ngFor="let month of months; index as i;"> [ERROR ->] {{ formattedMonth(month) | titlecase }} </div> </div> "): D:/GitProjects/BASFProj/projects/ssi- framework/node_modules/igniteui-angular/igniteui- angular.d.ts.IgxCalendarComponent.html@53:3
any help to get rid of this problem will be appreciated.
Hello Shahab Ashraf,
Thank you for contacting us.
It works well on our side. You can test it here - https://stackblitz.com/angular/jboyrvpnkrk. Please provide a reproducible working sample so we could further investigate.
