I'm trying to change the color of my date picker; however, it doesn't seem to be working. Below is from the component scss file:
Hi AK
I tried your example, it worked. But tags inside
Hello JK,
I have made a sample for you which is showing how you could change the header and content background of the datepicker calendar. You can intuitively continue modifing the theme.
I would like to point out the igx-date-picker is a composition of igx-dialog and igx-calendar components so that you have to use the themes that are connected to those two components in order to achieve some style changes on the date-picker.
Also please make sure that you have referred to the sass documentation before start using any of the theme configurations.
Here you can find the documentation about the igx-calendar-theme.
If you have further questions, please contact us again.
