280
Visual Studio Crash after Upgrade to Infragistics Ultimate 2014.1
When I try to open and Get Latest from TFS on a solution that my college has upgraded using the Version Utility for 2014.1, Visual Studio (VB.NET) 2010 stops working with the following message:
[Window Title]
Microsoft Visual Studio
[Main Instruction]
Microsoft Visual Studio has stopped working
[Content]
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
[Debug] [Close program]
I also get a couple of entries in the Windows Application Log:
VSTTExecution:
(devenv.exe, PID 7896, Thread 1) TuipPackage.InitializeTestProjectPlugins: System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualStudio.QualityTools.CodedUITestPackage, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. File name: 'Microsoft.VisualStudio.QualityTools.CodedUITestPackage, PublicKeyToken=b03f5f7f11d50a3a' at System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMarkHandle stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName, ObjectHandleOnStack type) at System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName) at System.RuntimeType.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark) at System.Type.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) at Microsoft.VisualStudio.TestTools.Tips.TuipPackage.TuipPackage.InitializeTestProjectPlugins() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
.NET Runtime:
Application: devenv.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NotImplementedException Stack: at EnvDTE.Project.get_CodeModel() at Infragistics.VSExtension.SolutionListener.ReportInitControlUse(System.Object) at System.Threading.TimerQueueTimer.CallCallbackInContext(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.TimerQueueTimer.CallCallback() at System.Threading.TimerQueueTimer.Fire() at System.Threading.TimerQueue.FireNextTimers() at System.Threading.TimerQueue.AppDomainTimerCallback()
Has anyone else had this problem or anything similar?
I'm running Windows 7 Pro, and I have other VB.NET solutions that seem to open with NO problem, but they all reference a DLL that is part of the solution that causes Visual Studio to crash when loading the IDE.
Jamie Irwin
