I am trying to reinstall infragistics on an a machine that was reformatted. However the current latest revision for 2012.1 is #2118, all the other installs in the office are on revision #2028 and the revision on the install file is #1001. I need to be on the same revision number as everyone else in the office, but I cant seem to find the isntaller for that particular revision.
Hello Tony,
Thank you for this information. I've provided the information you need through the support case.
revision 2008 for winforms and revision 1010 for wpf thanks
The different platform products we provide do not all have the same revision numbers. In order to provide you with what you need, I will need the specific build for the WPF product and for the Windows Forms product.
Thanks for the prompt reply, I need winforms and wpf installs. Also I was mistaken before the revision I need is 2012 vol 1 revision # 2008
If you could let me know which of our products you're looking to install, I'd be more than willing to provide you with the link you need through the support case I created to handle this issue: CAS-113735-M1T8V9.
