after installing ASP.NET (& WindowsForms) with NetAdvantage_Ultimate_20121 and running the Toolbox Command Line Utility (any CRL on any Product) i get the message:
"No products were loaded. Skipping creating configuration file."
Pre-installing already tried
OS: Windows 7 Prof SP1 x86
How can i solve this issue, thank you.
Antonio,
Assuming you are using Windows Forms, you could use NetAdvantage Ultimate 2012 Volume 1 as that is the last volume that supported .NET 2.0 and this can be downloaded from the archived downloads page.
If you are targeting a web platform, then you should be looking at our newer controls as the browsers have changed and you would need the newer ASP.NET or jQuery controls to target all modern browsers.
If you are using WPF or Silverlight, then you should upgrade Visual Studio to a later version as that will provide better support for those platforms.
Thank you for your quick response Alan,
Is there any product that you recommend to use in VS 2008?
In 2015 Volume 1 all of our products target .NET 4.0 and newer which means that you would need Visual Studio 2010 or newer.
I have Visual Studio 2008 Professional edition installed, but I get the same error : "No products were loaded. Skipping creating configuration file.", I've tried to add manually the controls, but even that didn't work. Anbody know any solution that can help me?
I'm working over Windows 7 Professional 64bit and Infragistics 2015.1 version.
Thank you in advance for your support.
My workmate told me about it, there was a little comunication problem between us. I installed proffesional now, and it works fine.
Thanks alot.
