I have just installed net advantage 2011.2 and want to upgrade projects developed against an earlier version but cannot find the project upgrade utiity. Is this still supported?
Hello stuied,
You can also download the version utility here (2nd link on the right side).
Elizabeth AlbertLocalization Engineer
The version utility should be at the root level in the start menu, right under the NetAdvantage 2011.2 menu. If you don't see this can you tell me what package you installed (ASP.NET, WinForms, NET, Ultimate, etc).
