Hi.. All...
How to add infragistics ultra grid my ASP.net Projet???
Thank you..
Thanks.........
Hello nalinsen,
Ultra Grid is a Windows forms control and I’m not sure if it will work with ASP.NET, you can try to host it in the web form.
If you have installed NET Advantage then you should be able to see all controls in the toolbox.
If there is no toolbox with Infragistics controls then see this forum thread: http://forums.infragistics.com/forums/t/57241.aspx
I like to know both......
Could you clarify? You want to use UltraWebGrid which is Classic ASP.NET control or you want to add Windows Forms Ultra Grid control?
Thanks.
i'm using NetAdvantage 2007
