222
Upgrade Utility failed
We wanted to upgrade infragistics from asp.net version 2008 to 2011. We bouht the infragistic 2011 and installed (Environment Windows Server 2003, Visual studio 2010, .net 3.5). We were thinking it should be smooth upgrade.But when I tried to use Version Utility, it has failed to upgrade.
I have tried to google it but I couldn't get any help.
I have pasted the log file which Version Utility provides.
04:36:45: Gathering volume and assembly information.
04:39:40: D:\CTLFreightBillProject\CTLFreightBillProject\My Project\licenses.licx appears to be read-only or not accessible for some reason.
04:39:55: D:\CTLFreightBillProject\CTLFreightBillProject\My Project\licenses.licx appears to be read-only or not accessible for some reason.
04:40:23: ProjectFile element: CTLFreightBillProject\CTLFreightBillProject.vbproj is being treated as a proj file.
04:40:23: Analyzing CTLFreightBillProject.vbproj...
04:40:23: The following project needs to have its references updated:
04:40:28: Upgrading Solution CTLFreightBillProject.sln
04:40:28: D:\CTLFreightBillProject\CTLFreightBillProject\Web.config has been backed up.
04:40:28: Replacement for Infragistics2.WebUI.UltraWebTab.v8.1 is Infragistics2.WebUI.UltraWebTab.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.Shared.v8.1 is Infragistics2.WebUI.Shared.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.WebDataInput.v8.1 is Infragistics2.WebUI.WebDataInput.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.WebSchedule.v8.1 is Infragistics2.WebUI.WebSchedule.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.WebScheduleDataProvider.v8.1 is Infragistics2.WebUI.WebScheduleDataProvider.v11.1.
04:40:28: Replacement for Infragistics2.Web.v8.1 is Infragistics2.Web.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.UltraWebNavigator.v8.1 is Infragistics2.WebUI.UltraWebNavigator.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.Misc.v8.1 is Infragistics2.WebUI.Misc.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.UltraWebListbar.v8.1 is Infragistics2.WebUI.UltraWebListbar.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.UltraWebGrid.v8.1 is Infragistics2.WebUI.UltraWebGrid.v11.1.
04:40:28: Replacement for Infragistics2.WebUI.UltraWebGrid.DocumentExport.v8.1 is Infragistics2.WebUI.UltraWebGrid.DocumentExport.v11.1.
04:40:28: No matching assembly located in available assemblies Infragistics2.Documents.v8.1
04:40:28:    at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyXmlFile.GetNewAssemblyNameBecauseOfNameChangedBetweenVolumes(String assemblyName, Int32 indexOfVolumePortionOfAssemblyName, XmlNamespaceManager xmlNamespaceManager, Boolean ignoreErrors)
   at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyXmlFile.LocateNewAssembliesNodeforCurrentAssembly(String assemblyName)
   at Infragistics.VersionUtilitySupport.Core.File.Types.WebConfigFile.FixAssembly(XmlNode n)
   at Infragistics.VersionUtilitySupport.Core.File.Types.WebConfigFile.UpgradeInfragisticsAssemblyTags()
   at Infragistics.VersionUtilitySupport.Core.File.Types.WebConfigFile.Upgrade(String rootDirectory)
   at Infragistics.VersionUtilitySupport.Core.File.Types.FileBasewithWebConfig.Upgrade(String rootDirectory)
   at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
Please help us to upgrade the project.
Thank in advance,
Saravanan
