Is it possible to get source code for previous versions of the WinForms controls. I currently have a subscription which is for 2010 volume 3 but have to support a previous version of the product (7.3).
Hello Andre,
In this situation, I would recommend contacting sales. If you provide them with the product key from 4.2, they should be able to get you the software.
Elizabeth AlbertLocalization Engineer
Hi Elizabeth
I have a similar situation that I have to support software that is still using Netadvantage 4.2.
The Product Key that I have for it was registered on another user’s profile that no longer works for us. How can I register the key on my users profile to download the software?
Regards
Andre du Preez
Hello qz5kxt1,
Are the 7.3 dlls or installer not available? Does the project not contain the .dlls in the bin folder? The machine on which this application was initially developed should have the product installed. The .dlls would be in the folder C:\Program Files\Infragistics\[Product Version]\[Product Name]\bin.
If the 7.3 product was registered under the same account name, the installer should be available under My Keys and Downloads on the website. The source code should not be necessary to support a previous version.
An alternative is to upgrade the project to 10.3.
Since this is a non-technical question, you could always call or chat with the customer support team.
