1140
Infragistics version compatibility
I got a issue.
I have developed some forms using NetAdvantage 10.1 Win CLR2X and in august I have updated my toolbox to NetAdvantage 10.2 Win CLR2X.
An now I updated my toolbox to NetAdvantage 10.3 Win CLR2X. So, when I try running my forms which has 10.1 tools it throws me an error as I removed them when installing 10.2. So, as I goes,
do I need to keep all versions of Infragistics in order to make all of my forms work along with using the latest versions of Infragistics.
Let me know.
This is becoming a critical issue.
Nagarjun.
  • 8607
    Suggested Answer
    Hello Nagarjun,
    It sounds like your projects still reference the older version of the controls.  In order to use the latest version of Infragistics controls, you should upgrade your project to the latest version.
    There is an upgrade utility link in the start menu under "NetAdvantage XXXX.X".  It should be called "Version Utility".  Using this utility, you can simply select the project to upgrade, and it can be done through a UI.
    Another option is to manually upgrade your projects.
    More information about upgrading can be found in our online help.
    Please let me know if you have any other questions about this.
    Elizabeth Albert
    Localization Engineer
