Just wanted to let someone know that the following link no longer works on the IG site community.infragistics.com/exemplars.aspx
This is the link used when you try to naviage to the reference applications from the Resources menu or the select the reference app link on Resources page.
Taylorcj67,
Thanks for the heads up! These reference applications have been relocated to other areas within the new community site. These should be accessible from wihin the respective platform areas.Along with the launch our new community site we released a unified samples launcher which you will find here: http://samples.infragistics.com/
Thank you again for the info on the link, I'll get a redirect setup asap!
Kevin
