HI!
I started the trial version of Xamarin and tried to reate a mobile app by using the Appmap product. I tried to follow the example given on the video for using Appmap. My Question is , Is it possible to edit the AppMap so I can try to add some UI's? If yes then How do I edit the AppMap UI design to add or modify pages?
Thanks!
Hello Roman Rapido,
Since it seems that this question is the same as that in https://es.infragistics.com/community/forums/f/general/121067/how-to-edit-appmap , I'll assist you there.
If you need to update about this matter, could you make a post there?
Thank you in advance for your understanding.
