I have a valid license for 2018.2, and have installed it before. I uninstalled it from the Control Panel, since my project wasn't compiling.
But when I try to install it again, I'm getting the following error: There was an error validating the key: {0} System.ArgumentNullException.
I'm presuming the uninstall was not clean. How can I wipe out all traces of Infragistics, and make a fresh start?
Navya.
Hello William,
Can you please specify which issue you are facing? Are you getting an error validating the key? Are you using the platform installer for the installation? If so, can you please provide the IGPlatformInstall.log file which is automatically created inside the "Log Files" folder?
In general, for new questions, it is suggested to open new case in our internal system.
RegardsVasil
I AM ASL FACING THIS ISSUE.
Hi Vasil,
When I changed the 'Specific Version' of the references to False, that did not help. But when my teammate made that change, and I pulled it in, I'm able to edit the designer! And he also checked-in his licenses file; maybe that helped too??
No idea, but I have it all working now.
Thank you for your help!
Hello Navya,
I am glad to hear that things are getting better.
In order to investigate the issue with the designer I will need some additional information, like Infragistics products and versions installed on the machine, version of Visual Studio that you are using, OS version. It would be nice if you can provide a sample with the issue, so I can try to reproduce and investigate it on my side.
The references were pointing to the installation folder. So, no changes needed on that front.
I just cleaned, rebuilt, but that didn't help either. Re-installed Infragistics, and repaired it; that fixed it. Thanks for your help!
I did not update to the service releases, but kept the version that came with the project, and was able to execute it. Everything is working, except I cannot make changes to the form in the designer. No idea why.
