Is it possible to write a custom text instead of the blank in the editor part of a multi-select UltraComboEditor when no selection has been made ?
Hi Chris,
Thanks for the solution, it works as I wanted it now.
Regards
Christian
Try the NullText property on the UltraComboEditor to see if it meets your needs. Let if know if this works out for you. Otherwise, we'll have to look into a creation filter to achieve this functionality.
Chris
