This usually happens because the dropdown component automatically selects the first item when the prototype runs. In Adobe XD (formerly Project Indigo), the hint text is only a visual placeholder in design mode and does not always behave like a true “empty” default value during prototyping.
A common workaround is to add a blank or “Select an option…” item as the first option in the dropdown list. This keeps the field looking empty when the prototype starts and lets the user make a selection afterward.
If you are using component states for the dropdown interaction, make sure the default state is the one that shows the placeholder or empty value before any selection is made.
