Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / How do I have the drop down width of an UltraCombo (or UltraComboEditor) be wider than the actual control?
Jamal
Jamal asked on Jan 8, 2010 10:13 PM
I have data to load in either an UltraCombo or UltraComboEditor that is wider than the space I have for the control. How do I make it so that when dropped down, the exposed list is as wide as the data I’m displaying, even though that’s wider than the actual control?
Thanks in advance,
J
    Mike Saltzman answered on Nov 19, 2008 7:35 PM
    What you are describing is the default behavior of the UltraCombo. If it's not doing that, you must have changed something. Maybe you set DropDownWidth to something other than the default.
    I'm not sure about the UltraComboEditor, but you might want to check the documentation on DropDownWidth. There are certain settings like 0 and -1 that have special meanings.
      Jamal
      Jamal answered on Nov 19, 2008 9:12 PM
      Mike,
      Thank you for your prompt reply. I have just added the UltraCombo fresh, set its datasource to a datatable, and hidden the column headers in the InitializeLayout event. I also hid some of the columns in that event. Of the only two columns that I am showing, the length of the data of one of the columns is greater than the width of the control. What settings should I have in place?
      Thanks again,
      Jamal
        Mike Saltzman answered on Dec 1, 2008 2:37 PM
        Hi Jamal,
        Ah, I think I misunderstood your question. The width of the dropdown is based on the combined width of it's columns. So it's not the width of the dropdown itself you need to adjust – you want to adjust the width of the columns to fit the data.
        You do this with the PerformAutoResize method of the column. You can call this method on each of the two visible columns inside the InitializeLayout event. Just be sure to use the proper overload and specify AllRowsInBand.
        Jamal
        Jamal answered on Dec 3, 2008 9:17 PM
        Mike,
        Thanks for the tip, I'll try it out if I get the chance. Any way to do it with an UltraComboEditor? That's what was originally being used, and I went back to it when I rolled back my changes.
        Jamal
        Mike Saltzman answered on Dec 4, 2008 3:21 PM
        Hi Jamal,
        I'm pretty sure that the UltraComboEditor does this automatically. Or perhaps it's a DropDownWidth setting.
        Don
        Don answered on Jan 2, 2009 4:21 PM
        To clarify for anyone ele having this issue:
         Setting DropDownListWidth to -1 should solve this issue and allow you to see all data no matter the width. (UltraComboEditor)
        by default the value is 0 and does not show all the data in the drop down by default.
        -Thanks Mike
        Brian
        Brian answered on Jan 8, 2010 8:46 PM
        This doesn't work for me.   I have an UltraCombo bound to an Object.   DropDownWidth is -1.  It's not as wide as my data.
        Mike Saltzman answered on Jan 8, 2010 10:13 PM
        The above post is referring to UltraComboEditor, not UltraCombo.
        For UltraCombo, you need to resize the columns and the dropdown will size itself by default so that all of the columns show.
        To resize the columns in the combo to their contents, you can use the PerformAutoResize method on the column (and loop through and call it on each column) or the PerformAutoResizeColumns method on the band or DisplayLayout. The InitializeLayout event is generally a good place to do this.
Jamal
16 years, 10 months ago
Feb 11, 2026 9:21 PM
