Right click menu option status
vls vls
vls vls asked on Nov 3, 2015 12:31 PM
I'm working on an infragistics application. My functionality is to test
1) right click on the grid –> working
2) right click menu has different option like "create","edit","remove" etc
3) I need to check if the edit and remove option is disabled in the menu
Please let me know how do i get the disabled property in a menu.
VLS
    Georgi
    Georgi answered on May 10, 2013 2:56 PM
    Hello VLS,
    Your question is not related with Infragistics and our TestAdvantage, because we have not ContextMenu control. Maybe you are using Microsoft`s ContextMenuStrip control in our UltraGrid. If so, then you could use the default functionality in the QTP and check if the Item from context menu is enable or not.
    You could use the code below:
    SwfWindow("Form1").Move 359,166
    SwfWindow("Form1").SwfTreeView("ultraTree1").ActivateNode "\Node13"
    SwfWindow("Form1").SwfTreeView("ultraTree1").Select "\Node13"
    SwfWindow("Form1").SwfTreeView("ultraTree1").RightClick ""
    SwfWindow("Form1").SwfToolbar("SwfToolbar").Select "AAAAAAA"
    If SwfWindow("Form1").SwfToolbar("SwfToolbar").IsItemEnabled("AAAAAAA") Then msgbox("Yes")  Else msgbox("No") End If
    SwfWindow("Form1").Close
    Please take a look at the attached video file for more details. Let me know if you have any further questions.
    Regards
      Georgi
      Georgi answered on May 16, 2013 6:17 AM
      Hello VLS,
      Have you been able to resolve your issue ? If you still have any concerns or questions I will be glad to help.
      Regards
        vls vls
        vls vls answered on Aug 6, 2013 4:20 PM
        We are currently facing issue with rightclick object.
        Application is built on Infragistics 2010 Vol3, and same version of TA license is used.
        Issue description:The right click object is identified SwfToolBar but at times it change to SwfObject, but once we clear the cookie and try again it identifies are SwfToolBar.
        Can you please suggests on this behaviour
        Surya Prakash
        Surya Prakash answered on Nov 3, 2015 12:31 PM
        Hi Georgi,
        Thanks for your suggetions and help in the technology.
        I have a issue that UFT 12.02 is not recognizing the WPF child objects.
        Will please suggest me in this.
        Surya
vls vls
10 years, 11 months ago
