I am writing in vb and you provided c#, anyway you can convert?
And just so I am making myself clear. I have a Boolean in my dataset that I want to convert to "Yes"/"No". And in another column I have a String field with two values (not "Yes"/"No") that I am converting to Boolean.
I have successfully changed the later in CheckEditorDataFilter but I can't apply that to the Boolean field because the values are different.
Public Function Convert(ByVal args As Infragistics.Win.EditorDataFilterConvertArgs) As Object Implements Infragistics.Win.IEditorDataFilter.Convert
Select Case args.Direction
Case ConversionDirection.EditorToOwner
args.Handled = True
Select Case CType(args.Value, CheckState)
Case CheckState.Checked
Return "35"
Case CheckState.Unchecked
Return "37"
Case CheckState.Indeterminate
Return String.Empty
End Select
Case ConversionDirection.OwnerToEditor
args.Handled = True
If args.Value = "35" Then
Return CheckState.Checked
ElseIf args.Value = "37" Then
Return CheckState.Unchecked
Else
Return CheckState.Indeterminate
End If
End Select
End Function
