Hi Teodosia,
When is the estimated release date for 202.2 SR1? BTW, you have an excellent name. Holding off using VS2022 until Infragistics formally supports it.
Steve
Thank you very much for your response. I was able to fix the issue.
Hi all,
I was having the same problem as mflach. I resolved the problem by calling the grid.columns.clear() method prior to databinding.
Hope this helps.
